Get from Drawing to referenced Part using API
Severin_123
Member Posts: 46 PRO
in General
get the views from /drawings/…/views
take the modelreferenceid parameter and use it in
appelements/…/references/{RFID}
Which should give the full doc/version id/partid
https://cad.onshape.com/glassworks/explorer#/Drawing/createDrawingTranslation supports a query param called evaluateExportRule. If you company has setup export rules correctly you can will this result as exportRuleFileName in response
