FeatureScript: opFunction with boolean for optional parameters
jelte_steur_info
Member Posts: 650 PRO
Hi,
I'm working on a featurescript using opFitSpline functionality.
I always use the endDerivative and startDerivative, but have added a boolean option to check/uncheck in the UI for the intermediary derivatives.
my code now looks like this:
// create a spline using the arrays
if (definition.derivativeEndOnly)
opFitSpline(context, id + "fitSpline1", {
"points" : pathPoints,
"startDerivative" : startDerivative,
"endDerivative" : endDerivative,
"derivatives" : derivatives
else
is there a cleaner way to disable the "derivatives" in one opFitSpline without having two different opFitSpline functions?
leaving the derivatives map empty hasn't worked so far.
MichaelPascoe
Member Posts: 2,803 PRO
See how the definition of the opFitSpline is a map { }. You can create that map beforehand then add only what you need to it, then feed it into the opFitSpline:
var splineDef = {}; splineDef.points = pathPoints; splineDef.startDerivative = startDerivative; splineDef.endDerivative = endDerivative; if (definition.derivativeEndOnly) splineDef.derivatives = derivatives; opFitSpline(context, id + "fitSpline1", splineDef);
RENDERCAD
________________________________________________________________________0
var splineDef = {}; splineDef.points = pathPoints; splineDef.startDerivative = startDerivative; splineDef.endDerivative = endDerivative; if (definition.derivativeEndOnly) splineDef.derivatives = derivatives; opFitSpline(context, id + "fitSpline1", splineDef);RENDERCAD
Got it!
thanks Micheal!
var fitSplineMap = {
fitSplineMap = mergeMaps(fitSplineMap, { "derivatives" : derivatives });
ah yes,
is cleaner than mergeMaps, but the idea is the same indeed
