FeatureScript: opFunction with boolean for optional parameters
jelte_steur_infojelte_steur_info Member Posts: 606 PRO
Hi,
I'm working on a featurescript using opFitSpline functionality.
I always use the endDerivative and startDerivative, but have added a boolean option to check/uncheck in the UI for the intermediary derivatives.
my code now looks like this:
   // create a spline using the arrays
    if (definition.derivativeEndOnly)
    opFitSpline(context, id + "fitSpline1", {
                "points" : pathPoints,
                "startDerivative" : startDerivative,
                "endDerivative" : endDerivative,
                "derivatives" : derivatives
    else
is there a cleaner way to disable the "derivatives" in one opFitSpline without having two different opFitSpline functions?
leaving the derivatives map empty hasn't worked so far.
  • MichaelPascoeMichaelPascoe Member Posts: 2,687 PRO
    edited October 2024 Answer ✓
    See how the definition of the opFitSpline is a map { }. You can create that map beforehand then add only what you need to it, then feed it into the opFitSpline:
    var splineDef = {};
    splineDef.points = pathPoints;
    splineDef.startDerivative = startDerivative;
    splineDef.endDerivative = endDerivative;
    if (definition.derivativeEndOnly) splineDef.derivatives = derivatives;
    opFitSpline(context, id + "fitSpline1", splineDef);
    var splineDef = {};
  • jelte_steur_infojelte_steur_info Member Posts: 606 PRO
    Got it!
    thanks Micheal!
    var fitSplineMap = {
        if (!definition.derivativeEndsOnly)
            fitSplineMap = mergeMaps(fitSplineMap, { "derivatives" : derivatives });
        opFitSpline(context, id + "fitSpline1", fitSplineMap);
    ah yes,
    is cleaner than mergeMaps, but the idea is the same indeed
