Procedural Text?
bernhard_petribernhard_petri Member Posts: 3
Hello dear forum members,
I've got a problem where I would like to procedurally add text in increments of 10mm to my part, stating a certain value (sort of like on a ruler). Is it possible to inject the text or change it using a variable/table inside an array of text objects?
Thanks for the help!
  • jelte_steur814jelte_steur814 Member Posts: 455 PRO
    one of the tricks is in @EvanReese 's video:
    it's well hidden, perhaps a checkbox in the UI would be clearer…
    'right click' 'convert to expression'
    edited October 2024
    I used an incremental variable called counter (using a custom feature, but this can be done manually as well), combined with a variable with an array of texts.
    I couldn't get the pattern to iterate through the array in the sketch somehow, but found a custom feature called Text by @MichaelPascoe that allowed it to work.
    check it out: Example Procedural text document
    using excel with concatenate functionality, is usually an easy way to create an array if it is too big to type…
    copy → 'paste with values' within excel → copy → paste in Onshape
