opBoolean targets from array of queries
graham_lock
Member Posts: 265 PRO
Hi,
I have code of the form below.
A number of faces are selected, sketches are drawn on the first and last face and then a loft is executed between those sketch regions.
The lofted part then needs to cut through all bodies (start, all intermediate and end) which are owners of the selected faces.
I'm building an array of qOwnerBody(face) but qUnion in opBoolean fails when passing that array of bodies.
How should I actually go about gathering all of the owing bodies to be cut?
annotation { "Name" : "Faces", "Filter" : EntityType.FACE }
definition.faces is Query;
opLoft(context, id + "loft1", {
"profileSubqueries" : [qSketchRegion(id + "startSketch"), qSketchRegion(id + "endSketch")],
var bodies is array = [];
for (var face in evaluateQuery(context, faces))
bodies = append(bodies, qOwnerBody(face));
opBoolean(context, id + "boolean1", {
"tools" : qCreatedBy(id + "loft1", EntityType.BODY),
"operationType" : BooleanOperationType.SUBTRACTION,
"targets" : qUnion(bodies, qOwnerBody(anotherFace)),
"keepTools" : true
Any help appreciated.
Thank you.
graham_lock
Just realised that qOwnerBody can take the faces query in my example so solved!
