Export obj or stl file from render studio with the texture attached
EternalPathEternalPath Member Posts: 7 EDU
A customer has asked for an obj file of the render I sent them with the textures attached so they can create their own renders.
Can I do this in Onshape? Or should I tell them that I can't provide that and I will have to use some other cad program to apply a different texture?
  • Paul_ArdenPaul_Arden Member, Onshape Employees, Developers Posts: 228 image
    Render Studio does not currently offer this functionality. Appearances in Render Studio are not simply a matter of textures but can be a complex combination of both textures and procedural functions which cannot be easily replicated in an OBJ file.
  • EternalPathEternalPath Member Posts: 7 EDU
    Thanks for your reply.
    I guess I will have to turn to Blender for this and go through the lengthy process of "Baking" a texture onto the object.
