Radial dimension not working
When trying to add radial dimension to a drawing I can see the cursor changes to detect the radius but nothing is detected when hovering over the curve on the drawing. The linear dimension do work without a problem.
  • martin_kopplowmartin_kopplow Member Posts: 1,078 PRO
    In that case, it is very likely that it is not a circle or arc, but an ellipse or conic. The drawing view might not be 100% orthogonal to the circle in the 3D model, making it's projetion a non-circular curve, and if it only was a tiny bit.
