How do I import a 3D DXF file to use?
paul_britton
Member Posts: 38 ✭✭✭
I have some 3D DXF files that are wireframe models. I want to use this data to build solid models from.
How do I do it in Onshape please?
Sorry, only just seen your reply....Ok, thanks, I'll try that0
I don't think we have support for 3d dxf import. At least not yet.
This is not the simplest conversion due to different nature of two worlds..
You can try following workaround, no guarantee that it will work in your case:
3d dxf --> stl
http://dgntodwgdxf.videoformat-converter.com/convert-dxf-to-stl.html
stl --> step
http://www.interop3d.com/apps/
If you get your files into step or parasolid format, Onshape will convert automatically during import.//rami0 -
I would try acis. That conversion should be possible in other systems. Then we can read ACISLou Gallo
Sr. Director of Product Definition. UX and Support2 -
