Measuring along perimeter made up of several edges
graham_lock
Member Posts: 265 PRO
Hi,
Referencing the image below:
I have flat parts where the perimeters may be comprised of combinations of lines, arcs and splines.
Taking the image as an example, if I have one point on the perimeter, is there a way to create another point at a given distance along the perimeter from that first point?
Any help appreciated.
Thank you.
graham_lock
I found the easiest way to achieve this is to create a path around the edges and then set points along the path:
path = constructPath(context, qEdges);
pointLocationsArray = [positionsOnSide]; // 0-1
lines = evPathTangentLines(context, path, pointLocationsArray );
The end points are then found using:
lines.tangentLines[x].origin
