Linear Patern Along a Curved Surface
I am still very new to CAD altogether so I'm looking for a solution that fits within my current knowledge. I'm trying to add a cutout on a part and copy that cutout across the part. I want to be able to adjust the overall length of the part and still have the cutout work. The cutout will start at the top, a flat face, and needs to end half way down to a curve. This depth to end will be different depending on where the cutout is.
Here is my sketch: https://cad.onshape.com/documents/0f68e4ff43da893d08ce530f/w/79b9fc08973cd06177e7c6b9/e/1e7e7dce16acfea7d1940d24
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 647 PRO
    Off of the top of my head, you could extrude a surface, then make an extrude remove up to that surface, linear pattern that extrude, then delete the surface.
  • EvanReeseEvanReese Member, Mentor Posts: 2,406 ✭✭✭✭✭
    Matts way is good if you don't mind the bottom of the cutouts not being totally perpendicular. I suspect these will be used for slotting together other laser cut pieces or something like that, in which case I'd want the bottoms of the cutouts squared off. Here's a way to do it using a Linear Pattern of a number of features including one that measures the distance and halves it for the depth. I used my custom Linear Pattern Plus feature as well so it will update the instance count to match the total length of the spine. https://cad.onshape.com/documents/42251c285060af9735584efa/w/dbb7883f7cb815784dcef851/e/37044636890653a11379dc86
