Can I sketch on a filet edge?
I'm trying to model a simple plastic screw cap to a water bottle and I want to include the little raised ridges that wrap around the filleted edge of the cap. Also I need to internally thread the cap. Any suggestions?
https://cad.onshape.com/documents/3e6dc67ded48b82be53194b2/w/28967affdb4c32d4c84539f1/e/dc953d6329bacb7635ba54ca
  • jelte_steur_infojelte_steur_info Member Posts: 606 PRO
    your document is not shared with the public. so we can't help you this way
  • David_YL_NguyenDavid_YL_Nguyen Member, Onshape Employees Posts: 182 image
    Hey @mark_richards818,
    I cannot access your document (private or deleted?).
    Check out this Tech Tip on using mate connectors to sketch:
    https://www.onshape.com/en/resource-center/tech-tips/mate-connectors-sketch-planes
