Why won't this loft work?
luke_diep245
Member Posts: 10 ✭
It renders on the other side of the sketch, but not the one sh
own
Technically this creates two degenerate points in one of the surfaces. NURBs surfaces are 4 sided, and you are essentially squishing two of the sides to zero. If the curves are all perfectly normal to that shared line, it might still work.
If you share a link to a public document, it will be easier for people to help.
