3D reading file
Robert_DeclosRobert_Declos Member Posts: 8 PRO
Hello, how can convert or save an Onshape 3D part into a 3D pdf viewer file?
  • martin_kopplowmartin_kopplow Member Posts: 987 PRO
    Adobe Acrobat (The authoring tool, not the free viewer) can read a few 3D-Formats Onshape can write. I don't dare to say CAD formats. It might be enough for simple visuals.
  • MDesignMDesign Member Posts: 1,126 PRO
    I don't believe onshape has that capability. You will likely have to export to a file type that can be imported to a program that supports 3d PDF creation and create the 3d PDF from there.. also could try searching Google for online 3d PDF creation. I haven't but it's an idea if you don't have access to a program that creates them.
