Drawing Export Shows Everything Except Part Views
Hi everyone,
I'm having an issue with exporting drawings. When I export my drawing as a PDF or image file, the resulting file displays everything in my drawing except for the views. All of the dimensions I have for each view display exactly as I have them located, but the actual views are invisible. The same thing happens when I try to print the drawing directly from OnShape.
I tried exporting the file as a DWG and opened it in DraftSight, and everything displayed properly.
I would like to be able to successfully export my drawings from OnShape as PDFs, so any help in resolving this issue would be greatly appreciated!
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,075 PRO
    That is strange. Could you share a link and we can try to duplicate the issue?
  • Sam_BritainSam_Britain Member Posts: 4
    I filed a ticket with OS Support and they think the issue was caused by the way I set up the drawing. I'm new to OnShape and I had some trouble trying to use a drawing template originally created in Draftsight in my OnShape drawing, so I ended up importing the template into OnShape as a DWG and copied and pasted it into a blank OnShape drawing. I then started duplicating that blank drawing as a way of using it as a template in OnShape. Even though this isn't the proper way of making a custom template, OS Support said it shouldn't have caused my exporting problem and so they filed a bug for it.
