How to create a dodecahedron connector?
Hi!
I want to create a connector for a dodecahedron and I have no clue how I can realize the many rotations that are needed to make it work.
Here is the geometry that I want to translate/rotate:
And in the end it should be something like this:
Can you point me in a direction, which tools I should use for that?
Thanks in advance!
In general, search the forums for "polyhedra" and you'll find a bunch of stuff. This custom feature is probably all you need:
https://cad.onshape.com/documents/2c40f522f1b5a02f6ce9ce01/w/32e0799ad10a8f40ac24abb5/e/dd23a5b64fbc7cefbf67ffbd
