new Featurescript: Statics Solver
joshtargojoshtargo Member Posts: 341 EDU
edited November 2024 in FeatureScript
I needed to calculate the force on a cable for a robot, so I decided to do it the hard way, but writing a FS to do it.
Link: Statics Solver
Pick your force locations (where they touch the object, flip the direction as desired. Outputs curves that are named and scaled to the force magnitude..
Can only do up to 3 unknowns, due to math.
Need to add checks for planar, and also make it work for any plane, currently hard-coded for YZ
