Spiral Sweep
joe_gehrer
Member Posts: 5 ✭
I am trying to make a tutorial vidoe for my students to make their own spiral fidget cones(seen here) but I can not figure out how to make the sweep twist as it does in this Fusion360 video. Any ideas for how I caould recreate this feature in OnShape?
Thanks!
there ist no link in your post.
One of these, I assume? https://www.thingiverse.com/thing:6613158
Apologies, not sure why the link didn't attach to the origional post, thank you _anton that is similar to what I was thinking. Any ideas how to do a sweep twist in OnShape
Noodled on the design a bit, came up with this:
https://cad.onshape.com/documents/631e99f6640ba9bc74ec80f1/w/c58d3266db16c4ec0385cc5c/e/44a17cf49805a6768f325fe1
It's not terribly parametric but works as a proof of concept. Maybe I'll try to print it later today…
_anton, thank you. Any chance you could do a quick screen recording on how you did that? I am very new to onShape and trying to keep 1 or 2 steps ahead of my student!
Thanks so much!
Honestly, the approach I took is a bit involved for a student. This design took some trickery.
You'd learn best, I think, if you copy the document and go through the features. Feature by feature:
Removeoption on. This will pattern both and subtract them from theinnerpart.Maybe it would be easier to design a regular fidget spinner or something like this screw thingy? https://cad.onshape.com/documents/1b4bcdcb1a5d67425fead370/w/d3a79293e608305d2cd0c866/e/b2081402443934b74a27933b
