UI Hint "REMEMBER_PREVIOUS_SELECTION" (FeatureScript)
darren_13darren_13 Member, Developers Posts: 120 PRO
I have a feature script that for many instances require me to select the same things (A plane, a few points and a solid) it would be good if I could get it to save the previous selection.
Cheers,
Darren
    I don't know your precise use case, but if you have a situation where you have multiple features needing to reference the same entities, perhaps a good workflow would be to have a setup "Start" feature which flags the necessary entities by setting context variables or entity attributes, and then successive features reference those entities.
    Alternatively, you can do it without making another feature by using editing logic: Remember the values of the previous feature in with context variables or attributes, then, using editing logic on feature creation, set the parameter value to the query you find, if any.
    To clarify a bit on why the obvious thing doesn't do the job: REMEMBER_PREVIOUS_VALUE works for almost all parameter types, but not Queries. That remembered value is associated the user (not the tab or the document), so when you're working in another Part Studio tomorrow, that previous value will still be remembered. This usually doesn't make sense for selections, which tend to have transient scope (they're nonsensical outside the single Part Studio, and even within the Part Studio they may not exist earlier or later in feature history). The workaround above gets around this by confining the scope to the current Part Studio, and performing an evaluation in the editing logic function to check if queried entity still exists.
  • darren_13darren_13 Member, Developers Posts: 120 PRO
    @kevin_o_toole_1, the editing logic sound very much like what I need. I'll have a play with this and let you know how it goes.
    Thank you very much for your help,
    Darren
  • ben_partouchben_partouch Member, csevp Posts: 158 PRO
    @darren_13 ,
    Did you manage to get this to work? I have the same scenario.
    Thank you
  • EvanReeseEvanReese Member, Mentor Posts: 2,590 PRO
    edited November 2024
    Here's an example of a way to do it. I commented thought process in the code, but let me know if you have questions. Perhaps someone could write it more concisely than me, but this works.
