Remove tap drill size from hole callout on drawing
Asa_Eckert_ErdheimAsa_Eckert_Erdheim Member Posts: 3 ✭✭
Is there any way to remove the drill size from a tapped hole callout on a drawing? I don't see any way to edit the default callout.
  • Jack_BrentanoJack_Brentano Member Posts: 12 PRO
    I agree this should be added. Currently if you want callouts not to feature it you have to dimension it with a note and type everything manually.
  • Jeremy_BardJeremy_Bard Member Posts: 3 PRO
    Yes, @onshape, please remove tap drill size from threaded hole callout on Drawings, or make it something that can be toggled.
  • MDesignMDesign Member Posts: 1,265 PRO
    probably needs to be entered as an improvement request
  • kate_leipold_ritkate_leipold_rit Member Posts: 43 EDU
    From an educator - I'm seeing that things dimensioned means things inspected. We can't inspect a tap drill size.
  • wayne_sauderwayne_sauder Member, csevp Posts: 629 PRO
    I can understand the reasoning stated here. However, I hope that Onshape does not just remove this but gives us the option. There are times I would want to show this on drawings.
  • GWS50GWS50 Member Posts: 491 PRO
    I also like to show this on drawings, some engineers I work with like to see all the info in the drawing
  • PeteYodisPeteYodis Moderator, Onshape Employees Posts: 566 image
    edited November 2024
    The overall plans are to make these things optional with hole callouts and likely at the company level - since these sorts of things are usually corporate norms. Hole callouts show up in other places besides just drawings - for example in the hole table in the part studio. Resulting tap drill sizes can be inspected in some cases - for example when a tap drill is used through the entire part but the thread is some depth that is not through the entire part. In a good amount of threads, the tap drill diameter is actually the minor diameter of an internal thread - and it can indeed still be inspected (gauge pins are one easier method of approaching that). Of course there are differences with materials and thread forming types (cutting versus thread forming), so the devil is in the details as usual.
    Typically the minor diameter of an internal thread is not all that consequential to an adequately strong and well functioning thread since most of the strength of the thread is from the root area of the cantilevered beam when we look at it that way. All that being said there is not one single standard/preference for what to show and not show on callouts and Onshape needs more flexibility for companies/users to decide what their callouts should be showing.
    Most of the drawings I produce are manufacturing instructions first. It's the engineer's job to understand how a part will be manufactured. In my experience, best practice is to have both manufacturing and inspection drawings.
    Having the tap drill size on there saves someone a bit of time going to look it up.
    Also all the other things others have mentioned above.
    I agree with @PeteYodis. Yes, pin gauges can be used to inspect minors. And yes, the thread's "drill" size can change based a few things that I can think of: 1. Using oversize taps/drills to compensate for plating and 2. using roll taps instead of cut taps as Pete pointed out. In these 2 cases the minor might not be the drill size. I misspoke when I asked to remove the drill size, as it is actually the minor that is being listed on the drawing. :-D
    Listing the theoretical minor and/or drill size of a thread on a print seems superfluous and is not a practice I have seen in all my years (unless its a partially threaded hole). Yes, the theoretical minor for an M6x1 should be 5mm, but this doesn't need to be called out on the print, and seems to just add clutter. If the engineer or machinist doesn't know what minor to measure to, or perhaps which drill size to use for a tapped hole; then I suggest referencing the Machinery's Handbook rather than trying to add all this information on a print. However, I do agree that it should be optional. :-)
    As far as a partially threaded hole, including the drill hole size and depths are necessary, though again this might not be the actual drill size needed to make the tapped hole, eg: the untapped portion is just a vent hole. Cheers.
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,035 PRO
    I too think it is not necessary information. It's like calling out the final diameter of a turned part, while instructing the machinist to take 3 passes to get there. That's not the designer's responsibility.
    I worked in a machine shop for a few years and the machinists just want the final thread callout, and the class of fit if its a specialized thread. How they make the thread is up to them.
    If it's a one off or a prototype sure. In a production environment you don't want variability in manufacturing methods. It can lead to quality and product issues that are very difficult to track down.
    Ideally the production drawings are created with some input from everyone who's going to use them. If someone then has a better way to do something you need to do it through change management to make sure it's logged and communicated to everyone else.
  • Carolyn_MyersCarolyn_Myers Member Posts: 7 PRO
    I agree, the minor diameter drill size is not the important thing I'm calling out, it's the final drill / tap / depth. Having the minor diameter in the dimension is distracting, and takes a little extra time to determine what the real requirement is. If Onshape could make it so that could be removed by the user and / or make it an optional setting to either include it or not in the displayed dimension, that would be helpful. I sure don't want to type it manually, since it would defeat the purpose of the parametric model. Has this been submitted as a change request?
  • Ste_WilsonSte_Wilson Member Posts: 537 EDU
    I always thought the purpose of a detail drawing was to include all the information needed for manufacture. This may be different to the information needed for inspection. I'll take a slight bit of clutter over having to have another source of truth in a drawer somewhere. I like that everything I need to know about the hole is in one call out :)
    Seems like some extra flexability is required though.
  • stg434stg434 Member Posts: 21 PRO
    At least in terms of the tap class callout — the drawing note should follow the settings in the Part Studio Hole feature. Unfortunately, when I uncheck the Thread Class parameter in the Part Studio it still displays the class in the drawing Hole/Thread callout.
  • Jessica_O_HairJessica_O_Hair Member Posts: 2
    Just adding my voice to this in favor of making tap drill sizes optional in the hole callout. It seems like everyone has a different opinion on whether they want to include it or not; making it optional in the drawing would make everyone satisfied. For us, it's useful in some situations, and clutter in others. Our shop prefers drawings without them unless it's a special circumstance.
