Drawings from Part Studio, yes or no please
devon_sowelldevon_sowell Member Posts: 52 ✭✭
The help shows making Drawings from a Part Studio, but when I right click on Part tab, the option is not there. I see it on Assembly tab only.
Devon Sowell
Engineering Consulting Partner
Professor, Engineering Technology, Palomar College, San Marcos, CA
sowelldevon@gmail.com
760 809 9046
CarlsbadCAD Carlsbad,CA
  • Narayan_KNarayan_K Member Posts: 379 ✭✭✭
    edited September 2015
    @ devon_sowell, You can see Create drawing option by Right clicking on part from model space or part list in part studio.
    1. From model space
    2. From Part list
  • navnav Member Posts: 258 ✭✭✭✭
    Hi @devon_sowell on parts studio to generate the drawing of a part RMB on the part and a menu will show up, one of the options will be create drawing, alternative you can also RMB Click on the parts list (on the part you want to create the drawing)
    Nicolas Ariza V.
  • peter_hallpeter_hall Member Posts: 196 ✭✭✭
    Doesn't show on right click on parts tabs along the bottom. Does show on a right click on the part in the tree on the LHS. I guess this is incase there are several parts within the parts studio.
    @devon_sowell , User can create drawing from part studio also by right clicking on part from model tree and model window as shown in below video.
  • devon_sowelldevon_sowell Member Posts: 52 ✭✭
    Please look at these photos, not able to access Drawing from Part Studio Tab, etc, Help file is different from reality
    Devon Sowell
    760 809 9046
    @devon_sowell ,  In first of your image that option is appeared as shown in below image
    In second image drawing option is not appearing because you are selecting feature (Import 1) in place of part .
    @ devon_sowell, If you want to insert many parts to drawing then it must be an assembly.If you can insert many parts from part studio then it will make confusion after wards to identify whether part it is a part drawing or assembly  drawing.
  • john_mcculloughjohn_mccullough Moderator, Onshape Employees Posts: 38 image
    @devon_sowell, it sounds like you are seeing something in the help documentation that is incorrect or misleading. I can't find any Help content that indicates a drawing can be created from the Part Studio tab menu. Please point out where you see the problem in Help and we'll get it corrected.
    john I misread this photo
    Devon Sowell
    760 809 9046
    @ devon_sowell, Image shown the options by clicking on '+' at the left bottom,not by clicking on part studio tab.
