Airfoil twist
I am building an f1 car and I am trying to make a realistic rear wing. I used a sweep to make the wing curl down at the edge like the 2022-2025 cars have. But I couldn't find a way to make the sweep variable, so the corners ended up having an angle of attack way to big. I then used a loft for the lower element which worked fine. But then when I did the same for the upper element, the shape goes wrong and gets too twisted at the edgeIs there a way to make this work as I am so close but can't figure out how to do it?
  • muhammad_tayyab_arifmuhammad_tayyab_arif Member Posts: 13
    Can you share your document for everyone's reference?
    I think you can get there using loft but try adding guide rails and increase your sketch faces (profile cross-sections) for loft command to follow
