Why does my sketch remain all blue in the clamp Exercise: Completing A Master Sketch
doug_blandingdoug_blanding Member Posts: 3 EDU
edited September 2024 in Learning Center
Upon completing this exercise, my sketch has one degree of freedom. It still operates with one degree of freedom between the two arms, which seems to be what it ought to do. Also the outlines of the two arms are blue, not black. But the completed exercise has the outlines in black and is fully constrained so it cannot be manipulated to show relative motion between the two arms. What's going on? I have shared my document with Onshape support and at https://cad.onshape.com/documents/65adec9951d00ffcf1c95028/w/cdc9bdb86808ebb343329f4c/e/b8fbfc2d140a530b6c6da5c8?renderMode=0&uiState=66dece10c6b90f54fd2d4fad
  • robert_scott_jr_robert_scott_jr_ Member Posts: 781 ✭✭✭
    Hey Doug. Can't get into your sketch to see what's going on. Please make your document public. - Scotty
  • doug_blandingdoug_blanding Member Posts: 3 EDU
    OK, see if you can get in now.
    I think I found the problem. The completed sketch (answer) is wrong. It has an extra horizontal constraint. See screenshot. To be correct, the sketch ought to show a dimension defining the gap between the long and short arms.
    @KatieHuffman This should be fixed in the Exercise, because the sketch is used later on to extrude actual clamp parts.
  • Lindsay_EarlyLindsay_Early Member, Onshape Employees, Developers Posts: 26 image
    @doug_blanding I just went through the exercise and it's correct. If you look at step 5 it does say those points should be horizontal.
