Symmetry tool
M_BÖHME
Member Posts: 10 PRO
Hi
When I import parts, i often need to check symmetry. How do i do that ?
It seems that the simple tool is missing ??
eric_pesty
Member, pcbaevp Posts: 2,554 PRO
There isn't an automatic way but you could do a split feature (using a mate connector directly) and mirror the one half with the "intersect" option, any material left indicates assymmetry so it doesn't take a lot of steps.
I should also be pretty simple to do this in Featurescript if that's something you do a lot...2 -
Caden_Armstrong
Member Posts: 395 PRO
I'm reviving an old thread, but I have made a feature to achieve this:
https://cad.onshape.com/documents/dbc618f5385d62322ab64ddf/w/8e8cc30dbe8d631926fe4be4/e/303589cc9047018cea1735d1www.smartbenchsoftware.com --- Renaissance --- fs.place
Experts in Onshape Automation - Custom Features and Integrated Applications4
Thank you ☺️ This is perfect
