I am trying to be able to select a complete curve automatically
Axel_Kollmenter
Member, pcbaevp Posts: 436 PRO
I am currently in the process of adapting a feature script so that it is perfectly adapted to our requirements. Similar to the sweep feature. How can I implement it so that I simply select the created curve, or I select a part of the spline and all tangential edges are automatically selected?
Currently I have to select each edge of the curve individually, which is quite time-consuming
Best regards,
Axel Kollmenter
Axel Kollmenter
Hi Axel,
If the curves are tangent you could use advanced selections
If you want to do it within the featurescript, you can do:
qTangentConnectedEdges(seed)
If the wirebody doesn't have exclusively tangent connected edges, and you just want all of the edges of a wirebody
qOwnedByBody(qOwnerBody(seed), EntityType.EDGE)
Will get all the edges owned by the body that owns the input edge
