I am trying to be able to select a complete curve automatically
Axel_KollmenterAxel_Kollmenter Member, pcbaevp Posts: 436 PRO
I am currently in the process of adapting a feature script so that it is perfectly adapted to our requirements. Similar to the sweep feature. How can I implement it so that I simply select the created curve, or I select a part of the spline and all tangential edges are automatically selected?
Currently I have to select each edge of the curve individually, which is quite time-consuming
Best regards,
Axel Kollmenter
  • Urs_Egger_REACTUrs_Egger_REACT Member Posts: 119 PRO
    Hi Axel,
    If the curves are tangent you could use advanced selections
  • Caden_ArmstrongCaden_Armstrong Member Posts: 400 PRO
    If you want to do it within the featurescript, you can do:
    qTangentConnectedEdges(seed)
    If the wirebody doesn't have exclusively tangent connected edges, and you just want all of the edges of a wirebody
    qOwnedByBody(qOwnerBody(seed), EntityType.EDGE)
    Will get all the edges owned by the body that owns the input edge
