Projecting a solid or surface onto someting else
martin_kopplowmartin_kopplow Member Posts: 991 PRO
edited November 2024 in Using Onshape
Maybe I'm not seeing the obvious, but what would be the best way to project the outline of a solid onto a plane or face in a given direction? My solid in question has round shapes and fillets all over, so I cannot project the edges. I need this to make fixtures and transport cases that should match the exact outline of the solids (or even assemblies). I know I could 'use' in sketches, but that'd require me to know in advnce, which faces are the outmost, ab´nt then trim the intersecting ones and figure everything out. I am loolkng for a way to just selecte the solid(s) to project, a direction and a target. The result shoud be a closed set of continuous curves.
