opSplitPart not behaving like UI split part
graham_lockgraham_lock Member Posts: 262 PRO
Hi,
Referring to the image below:
I want to split the part with the surface to give inner and outer parts.
I'm using
opSplitPart(context, id + "splitPart1", {
"targets" : targetPart,
"tool" : qCreatedBy(id + "extrudeOuterEdges", EntityType.FACE),
"keepTools" : true
As you can see at the front left, the split is splitting the part full length below the surface giving me an upper and lower part, rather than the required central and outer parts.
If I manually split the part using the surface it works absolutely fine.
Any thoughts appreciated.
Thank you.
  • GregBrownGregBrown Member, Onshape Employees, csevp, pcbaevp Posts: 368 image
    edited November 2024 Answer ✓
    The tool you are trying to split with is specified as EntityType.FACE, which is not what you want. You'll need to construct your query such that it returns a BODY…
  • graham_lockgraham_lock Member Posts: 262 PRO
    Thank you!
