Measuring an oval
k_koderak_kodera Member Posts: 9
How can I create an oval in Onshape with a specific inside dimension?
A circle is easy, but I don't know the formula for an oval.
  • robert_scott_jr_robert_scott_jr_ Member Posts: 604 ✭✭✭
    Use the Ellipse tool and enter the dimensions in the boxes that appear after clicking to create the oval. Otherwise use the Dimension tool. - Scotty
  • martin_kopplowmartin_kopplow Member Posts: 834 PRO
    If you need an oval (as opposed to an ellipse, for which you can use the ellipse tool), you may want to try the "Slot" tool. Based on a straight centerline, it will create an oval by dimensioned offset.
