How to create a bevel? Wie erstelle ich eine Schräge
Hi,
ich bin neu auf Onshape und würde gerne die gelbmarkierten Flächen von der oberen Kante bis zur unteren Ebene anschrägen. Die Maße aktuell sind 5x5x5 mm. Danach soll die blaute Fläche nur noch 2x2 mm sein. Kann mir vielleicht jemand sagen, wie ich das machen? Vielen Dank für die Hilfe :-)
Hi,
I am new to Onshape and would like to bevel the yellow marked areas from the upper edge to the lower level. The current dimensions are 5x5x5 mm. After that the blue area should only be 2x2 mm. Can anyone tell me how to do this? Thank you very much for your help :-)
  • glen_dewsburyglen_dewsbury Member Posts: 1,124 PRO
    If the four stubs are done as a separate extrudes the it can use draft angle.
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 698 EDU
    Or use the Draft tool.
  • stephan_roschestephan_rosche Member Posts: 8
    Hi Matt
    thanks for your help, this looks exactly what I need. But which steps do I need to select exactly?
    I proceed as follows:
    1. mark the vertical surfaces
    2. select bevelled shape and angle of 10 degrees
    Unfortunately, nothing happens. What am I doing wrong?
    Hi Matt
    Hi Matt
    with a bit of trial and error and the onshape help I have now managed it. Thank you very much :-)
