polygon line
Hi, I'm trying to thicken a polygonal line on an origami rabbit (to make a kind of spider web), but the program doesn't want to allow me to do this for the entire polygonal line and I can only cut out individual sections, then I have to make a new sketch and if I mark the wrong section, nothing works again... Is there a way to do this (quicker)?
  • MDesignMDesign Member Posts: 1,265 PRO
    You can leave everything in the sketch. No need to do multiple sketches. Just do multiple thin extrudes referencing different parts of the sketch until you have done them all.
  • EvanReeseEvanReese Member, Mentor Posts: 2,695 PRO
    This kind of thing is kind of laborious, especially to make the design really stable if you change something. I just whipped up this no-frills custom feature for you that can handle it though. Thin Extrude Network. If I find myself using it I'll probably put in more work to make it feel more like the real extrude feature.
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,475 PRO
    Also:
    rib network FS might work
    https://cad.onshape.com/documents/67de1cda4399707a3649fcdf/v/26c4d9efa4f624f567914d8b/e/484089617c304a5cb5cb0ac5
  • michael_beck289michael_beck289 Member Posts: 5
    Holy crap, I'm blown away by how well this works! Thank you so much! This saves so much work! THANK YOU!
    Also:
    also perfect! I am enthusiastic about the community! Thx!
