Hebrew support
guy_rogelguy_rogel Member, User Group Leader Posts: 97 PRO
It would be greate if I could add notes in hebrew.
Currently hebrew fonts are not supported.
    You can mention this requirement under improvement request category at
    https://forum.onshape.com/categories/improvement-requests
  • moran_hagormoran_hagor Member Posts: 8 PRO
    Apparently the link mentioned above is no longer working, and here is probably the right place for improvements requests, so I also join the original request:
    Please improve the Hebrew font support.
    Attached is a demonstration where I try writing some Hebrew, but in the sketch itself the letters flip direction, which renders the sentence as unreadable.
    I post here some Hebrew so you could try yourself
    תיק כלי מגע
  • sergey_gosergey_go Member Posts: 3
    edited August 2022
     I write Hebrew letters in reverse order, for example: שלום - ם1,ו2,ל3,ש4
     Anyone who can - write a script for Hebrew please
