How do I extrude along this path?
stephen_sherwood846
Member Posts: 26 ✭✭
I am trying to extrude the hexaganal shape along the construction path, but I can't work out how to do it. I thought I would select the hex shape, and then check "direction" which would allow me to click on the path. Howeever it will not let me select the arch shaped path shown below. Is there any way of doing this?
loft and sweep can use paths.
Sweep.
Awesome thanks.
