different parts to combine
Hello, i´ve a problme to create on part.
If would now print it with a 3d-printer, i get several different parts. but i want to have it as 1 holder.
How i could proceed?
    Presumably your extrusions didn't intersect the rest of your model when extruded, hence it's created new parts instead of merging with the existing.
    You should go back and edit the feature definition so they merge.
  • MDesignMDesign Member Posts: 1,352 PRO
    Or you didn't have merge checked on when you did the extrusion
  • glen_dewsburyglen_dewsbury Member Posts: 1,307 PRO
    Can you make your document public and post a link? Much quicker to see the problem first hand.
  • EvanReeseEvanReese Member, Mentor Posts: 2,884 PRO
    I don't think you actually need them to merge in Onshape to print as one part. If you want to anyway then you're looking for the "Add" mode for your extrude features or the Boolean feature
