The Meaning of 'startParam' and 'endParam' Parameters in Conic Sections
Member Posts: 3 EDU
edited December 2024 in Community Support
I would like to understand how startParam and endParam determine the start and end points of a conic section.
As shown in the diagram, when defining a conic segment, we need three points: A (start), B (end), and C (control). Point M is the midpoint of AB, and the ratio MD/MC is equal to rho. When the conic is clipped, two additional parameters, startParam and endParam, define the start and end points.
I have experimented and found that in the case of a parabola (where rho = 0.5), for example, point E is the end point, and the ratio AF/AB equals to endParam (with EF being parallel to CM). However, this does not seem to be the case for elliptical arcs and hyperbolas (where rho ≠ 0.5).
AF/AB = 0.75
rho=0.5: endParam=0.75
rho=0.8: endParam= 0.8931498239186069
rho=0.3: endParam=0.6887505003980625
My previous statement may have been incorrect. If you could point it out and tell me the significance of startParam and endParam parameters, I would greatly appreciate it.
  • Member, Mentor Posts: 2,319 ✭✭✭✭✭
    I'm not exactly sure where you're seeing these params listed, but it sounds to me like it's for "trimming" the conic ends. In your diagram the untrimmed conics seems like they would all end at B. The parameter is like a percentage along the curve from 0 to 1, so a param of 0.75 means that end point is 75% along the untrimmed conic. Just a guess that's what this is about.
    Independent Onshape Consultant | Industrial Designer
  • Member Posts: 3 EDU
    Thank you so much for your reply.
    After creating a sketch in a Part Studio, I used the API to retrieve its features. (Referring to: Onshape REST API)
    In the response body, the data for a conic section looks like this:
    "btType": "BTMSketchCurveSegment-155",
    "offsetCurveExtensions": [],
    "startPointId": "VZokbKpMKPZk.start",
    "endPointId": "VZokbKpMKPZk.end",
    "startParam": 0,
    "endParam": 0.7499999999933301,
    "geometry": {
    "btType": "BTCurveGeometryConic-2284",
    "points": [
    -0.3112278313995108,
    0,
    -0.3205652278652996,
    0.09430818740821202,
    -0.20065740367923754,
    0.02425698899981503
    "rho": 0.5
    "centerId": "",
    "internalIds": [
    "VZokbKpMKPZk.0.internal",
    "VZokbKpMKPZk.1.internal",
    "VZokbKpMKPZk.2.internal"
    "isConstruction": false,
    "isFromSplineHandle": false,
    "isFromSplineControlPolygon": false,
    "isFromEndpointSplineHandle": false,
    "parameters": [],
    "namespace": "",
    "nodeId": "MbbV8dmyIgK0GFfGA",
    "index": 0,
    "entityId": "VZokbKpMKPZk"
    As you correctly pointed out, "B" represents the end point. After the conic is trimmed (I apologize for the incorrect term I used earlier), the endParam becomes relevant.
    I understand that the parameter value (e.g., 0.75) represents a percentage from 0 to 1, but I am unsure of what it specifically refers to in this context. As shown in the diagram, the length of the trimmed conic (highlighted in yellow) is 91.202, while the total length of the original conic is 157.932. However, this does not yield a ratio of 75%.
    I observed that when rho equals 0.5, the value of endParam appears to correspond to the ratio AF/AB. However, this relationship does not hold when rho deviates from 0.5.
    Ah well I may be in over my head then, but parameterization isn't always 1:1 correlated with length for reasons I don't know. For that look into Arc Length Parameterization.
    Thanks a lot for your reply. I'll look into arc length parameterization to get a better understanding.
