how to get the boolean function to work with my part studio?
 Zetta_Hutton
                    Member Posts: 4 ✭
Zetta_Hutton
                    Member Posts: 4 ✭
            I'm completely new to onshape so apologies if this is really obvious or the link doesn't work or anything, but boolean isn't working on my part studio and i'm unsure how to fix it. Thanks!
https://cad.onshape.com/documents/046266b7cbbaf2273f8c31ce
Your document is set to view only. Can you set it to allow it to be copied?
I'm so sorry but how do you do that? I've turned export on but I can't find it. I'm not technically the owner of the document, that could be an issue?
If you're not the owner, I don't think you can change that…its tough to diagnose without 'digging in" on how the model was constructed. There are no boolean's shown in the doc as it is now so it makes it even harder to figure out what you're having trouble trying to boolean. 😉
