Best way to query threaded faces (tapped Hole and External Thread)
EvanReese
Member, Mentor Posts: 2,806 PRO
I'm working on a feature that needs to find faces with hole attributes or external thread attributes. Can this be done with qHasAttribute()? I'm not sure where to find the "name" to filter for.
1
Caden_Armstrong
Member Posts: 388 PRO
I think holes were made before named attributes were a thing, so they are found based on the value pattern.
You have to take a query of seed faces and check which faces have the attribute pattern:var seedFaces = qEverything(EntityType.FACE); for (var f in evaluateQuery(context, seedFaces)) { var attributes = getAttributes(context, { "entities" : f, "attributePattern" : {} as HoleAttribute } ); if(size(attributes) > 0) { println(attributes); } }www.smartbenchsoftware.com --- Renaissance --- fs.place
Experts in Onshape Automation - Custom Features and Integrated Applications1
var seedFaces = qEverything(EntityType.FACE); for (var f in evaluateQuery(context, seedFaces)) { var attributes = getAttributes(context, { "entities" : f, "attributePattern" : {} as HoleAttribute } ); if(size(attributes) > 0) { println(attributes); } }Experts in Onshape Automation - Custom Features and Integrated Applications
Aw man, that's what I was starting to do, but it felt wrong somehow. Thanks, Caden!
You could start with a smaller seed query by taking all the faces and putting it through qHoleFaces
