Best way to query threaded faces (tapped Hole and External Thread)
EvanReeseEvanReese Member, Mentor Posts: 2,807 PRO
I'm working on a feature that needs to find faces with hole attributes or external thread attributes. Can this be done with qHasAttribute()? I'm not sure where to find the "name" to filter for.
  • Caden_ArmstrongCaden_Armstrong Member Posts: 389 PRO
    I think holes were made before named attributes were a thing, so they are found based on the value pattern.
    You have to take a query of seed faces and check which faces have the attribute pattern:
        var seedFaces = qEverything(EntityType.FACE);
        for (var f in evaluateQuery(context, seedFaces))
            var attributes = getAttributes(context, {
                    "entities" : f,
                    "attributePattern" : {} as HoleAttribute }
            if(size(attributes) > 0)
                println(attributes);
                    "entities" : f,
  • EvanReeseEvanReese Member, Mentor Posts: 2,807 PRO
    Aw man, that's what I was starting to do, but it felt wrong somehow. Thanks, Caden!
    You could start with a smaller seed query by taking all the faces and putting it through qHoleFaces
