Logitech mx master 3 Customer Mouse
Hi,
Does anyone know if you can program the Logitech mx master 3 so the buttons work with On-Shape?
I cant seem to work out if it can be done as its web based software.
  • RhettRobinsonRhettRobinson Member Posts: 201 ✭✭✭
    Yes, I use an MX Master 3 and have buttons setup for Enter, Escape, Delete, and Undo/Redo. Just use the keyboard shortcuts to set them up. I don't believe you can make them Onshape specific since it is browser based, but I would rather have Onshape shortcuts than ones for my browser.
  • aaron_harris672aaron_harris672 Member Posts: 11 PRO
    Great I will give this ago. Thanks
  • CoastJRACoastJRA Member Posts: 2 EDU
    i am trying to make it so the side scroll pans the object do you guys know of any way
