Making a grommet to fit a curved surface
dave_woodward078dave_woodward078 Member Posts: 12
I'm trying to make a grommet to fit the attached setup. This represents a roll-bar passing through a car body panel (will actually extend beyond the surface it cuts through) which is just off perpendicular.
I want to create a grommet from the body panel which will accommodate the angular offset. Is there a way that I can use the cut face of the panel to create a new part?
Thanks
