How to make a hull shape using 3 view sketches?
brian_wagener
Member Posts: 22 ✭✭
I have created 3 sketch views, and would like to make a 3d hull out of this. Can this be done with something like loft tool?
Great start with those three profiles. For me, the next step is often some projected curves and then a loft.
https://cad.onshape.com/documents/7b265f9547ea96d0c8af0858/w/a086dde488156e48d7b16a86/e/c1cee5404be702efa627b5eb
Thanks, looks good especially the project curves. The only issue is the loft doesn't actually take into account the rear sketch. Actually I don't think your drawing uses that sketch at all. How could I include that in the loft?
Good point. I just made a sketch called Rear Guide that uses the rear sketch profile and added that as a guide to the loft.
