ANYTHING I add to a 4 item sketch causes undefined! A tad frustrating...
martin_mucklemartin_muckle Member Posts: 4
There is 1 circle, 1 arc and 2 straight lines. Anything I try to add causes undefined error. How can I have gone wrong so soon? Please help. Thanks
  • S1monS1mon Member Posts: 3,651 PRO
    Without "Show Constraints" on, or direct access to a public document, it's impossible to help solve your issue. Most likely you have things over-constrained, but in a way that Onshape is not immediately flagging.
    Undefined or over defined? Yes, anything new you add will typically be undefined until you define it/constrain it. So all normal.
  • jelte_steur814jelte_steur814 Member Posts: 539 PRO
    please note that defining everything is best practice, but an undefined sketch is not an error. just a warning that things may move around if you open it again and drag stuff or move unexpectedly if underlying referenced geometry changes.
  • martin_mucklemartin_muckle Member Posts: 4
    Thanks everyone. This is very useful. I will deffo check out all the points made.
