Transform in "for" loop strange behavior
christopher_dziubachristopher_dziuba Member Posts: 110 ✭✭✭
I've made a featurescript that spaces parts with an exact gap away from each other along a plane No mater what their shape or orientation (yes I am fishing for brownie points).
HOWEVER! The last transform in the last loop seems to change it's vector despite the debug tool showing the vector is correct:
        var moveVector = spaceDist.sides[0].point - spaceDist.sides[1].point; //Distance result points to get a vector
        var clusterTransform = transform(moveVector / 2);
        var nonClusterTransform = transform(-moveVector / 2);
        opTransform(context, id + "2ndLoop" + m + "moveCluster", {
                    "bodies" : clusterBodies,
                    "transform" : clusterTransform
        opTransform(context, id + "2ndLoop" + m + "moveNonCluster", {
                    "bodies" : nonClusterBodies,
                    "transform" : nonClusterTransform
        var partBodies = qUnion([partMap.part, partMap.gapPath, partMap.spiralPath]);
        clusterBodies = qUnion(clusterBodies, partBodies);
        nonClusterBodies = qSubtraction(nonClusterBodies, partBodies);
This is supposed to be equally spaced and the vectors confirm that:
This is debug of the "moveVector" and I have drawn the equivalent transforms.
My script essentially loops through the selected parts one by one and once the part is "spaced" its added to a query called "clusterBodies" and removed from "nonClusterBodies" so that the cluster is spaced from non cluster part by part until all have been spaced. So in theory those 3 square parts should be equally spaced but the top one aligns with one side for some dumb reason. I have already confirmed that the parts are being looped through in the correct order. Please help:
The part studio I'm testing in
The Feature Studio
  • christopher_dziubachristopher_dziuba Member Posts: 110 ✭✭✭
    Never mind I figured it out. Such an idiot hahaha, I was transforming all remaining parts rather then just the next part in question
    If you want some explanation on how the spacing itself is calculated it's pretty strange and complicated so I'm happy to elaborate here. Just ask
    Just tried rewriting everything to simplify it and reduce the number of variables to no avail
