Fixing Broken Part Through FeatureScript
rachel_kannair
Member Posts: 4 ✭
I was finishing up a model cable protector earlier today, when a new fillet I created caused the Part Studio to completely fail. I can't open or edit the Part Studio. If I could just delete the last fillet I made I would be set, but I can't. I was wondering if there is a way for me to recover my work, potentially by taking the code generated for the part & removing the fillet in the code, then opening directly from the code. The Part Studio is named "V9" and the corrected code is named "Feature Studio 2." I'm totally new to Part Studio so my terminology and understanding of the system may not be correct. Any help would be greatly appreciated.
https://cad.onshape.com/documents/a4d17625d4e0c7db5f6ad66f/w/be602ad1caa7b2bd6c34d3ee/e/5acacc221ff23aa2662255b9
could you roll back the document to an older point in history in the version graph? You should be able to restore to just before the fillet was added.
Oh silly me, I've been using Onshape for a year and never even realized that was a feature. Thanks!
