Disabling Regeneration
paul_berry
Member Posts: 9 ✭✭
Is there a way to disable part regeneration until I am done making changes? Sometimes I need to make a lot of changes, and after each change the part disappears and features lower in the tree are unavailable or very slow to open. I would like to disable regeneration, make all the changes, then enable regeneration. Then I will have time to do something else while it chews on my input. Otherwise I can spend a lot of time staring at the swirl, waiting to make the next change.
We very recently implemented this. :D
I've always been a little slow.
Thank you!
