flat faced circles
ive noticed on some circles that it gives flat faces when i thicken into sheet metal parts. why is this please? i dont want it to cut like that when i export the dxf
  • MDesignMDesign Member Posts: 1,337 PRO
    it won't. just keep going. its just a "less expensive" way for the computer to display arcs/circles. use high quality display setting or change the tessellation level for the part that you want to get more smooth. your exports will do whatever level of detail you set them at.
  • kevin_mason558kevin_mason558 Member Posts: 67 PRO
    so if it's drawn a circle
    It'll cut as a circle
    Even though it's showing faces?
    Thanks @MDesign
    Yes. if you've drawn it with arc and circles. dxf will have arcs and circles. fwiw on simple designs you can change the the display setting to view in high quality and see smooth curves. if its a complex design you may want to control that with tesselation setting shown here.
    @kevin_mason558 I should note though most cutting/printing systems convert arcs and circles to small lines anyway but what you see on screen is not related to those results.
  • rick_randallrick_randall Member Posts: 417 ✭✭✭
    You can change tessellation by typing ( shift+r ) , this gives you high quality rendering. Same thing as MDesign said, just a shortcut
  • S1monS1mon Member Posts: 4,082 PRO
    Shift-r is also temporary, which can be good for avoiding overly bumping up the tessellation.
