Where did the variable button go?
In the past, when I wanted to create a variable, I would go to the Part Studio and then click on the variable button (x). Now I can't find the button. Where did it go? I've been looking for it for more than an hour.
  • Narayan_KNarayan_K Member Posts: 379 ✭✭✭
    edited November 2017
    @brain_coller, depending on your window size it may be in drop down menu
    Hi @brian_coller ,
    If you haven't customized your toolbar, it may be hiding in a tool group behind one of the menu options in this group:
    If you have customized your toolbar, it could be absent from your toolbar in general (if it was removed).  This help page has information about customizing your toolbar:
    https://cad.onshape.com/help/Content/toolbars.htm
    If its completely lost, the first step may be to go into the customize toolbar mode and check whether its been deleted.
    If your variable tool has been removed, the customize toolbar mode would look like this: (with variable in the box on the left)
  • bernard_lucasbernard_lucas Member Posts: 11
    I am facing the same kind of problem.
    I have not customised any toolbar. The only thing that has recently changed for me is that I have started to play around creating some FS. I have now one more button on my toolbar (local FS).
    On the following printscreen, we see that even the "search" does not find the "variable button"!
    Here is the customised tool bar screen:
    Refreshing the page did bring it back!
    I am on chrome, Sequoia 15.2
  • rick_randallrick_randall Member Posts: 394 ✭✭✭
    This may, or may not help, but you can use "ctrl+(+)" or "ctrl+(-)" while hovering cursor over the command button line, in order to change screen resolution - this could maybe help with command button crowding on smaller PC screens.
  • g_p484g_p484 Member Posts: 4 ✭✭
    I am facing the same thing, the variable button is nowhere to be seen, like bernard_lucas showed. Why is that? I use it all the time, and I am teaching a friend a the moment, and it's a bit daunting for a newcomer to use "search" to find a hidden tool. Is it a bug or a new way to work?
