Part number embossed on part?
martin_kopplowmartin_kopplow Member Posts: 837 PRO
edited January 8 in General
This just came up when discussing a current project on the shopfloor: Is there a way to more or less automatically emboss/imprint a part number (or some other part property from the BOM) onto a part? Maybe at a location specified by a mate connector or whatever marker may appear useful? At first glance, this appears to be a job for a FS …
The background is the shop messed up similar looking 3D printed and laser cut parts. 🤣
  • EvanReeseEvanReese Member, Mentor Posts: 2,456 ✭✭✭✭✭
    As it turns out, even FS can't save you here as all of the part properties generate after the feature list, so PNs aren't accessible to a custom feature (unless that feature is also setting the PN). I think it would need to be something with the API that reads it and updates a variable every so often. I've wanted something like this for a similar purpose. For example, if I'm iterating on 3D printed mockups and changing each one, I'd like to have the version number and date automatically added.
