I have an .stp file that I imported. Many surfaces Zero parts - This prevents making drawings, no?
Paul_99
Member, OS Professional Posts: 29 ✭✭
I managed to delete some surfaces (Ones I wanted to delete even!) and they became parts once they were deleted - interesting I thought. But in the lower left listing I have a bunch of surfaces and 0 parts and Parts seem to be required in order to make drawings - which is my current goal.
For some cases, "Extrude/up to surface" might be a better bet.
Extrude UP to surface is next on my experimental voyage.
You can extrude a trimming surface at approximately right angles through the problem area to trim it away (using "Split")
At least, I think this is currently possible.
But first just try reducing the thickness to a really small value and see if this works.
The other problem you might strike is "Zero Thickness Geometry" which can arise where you thicken two adjacent surfaces which are not strictly tangent to each other. If this is happening, you need to arrange things so that the surfaces in question create separate parts. ZTG is not permissible in a single part.
I'm off to learn how to snuggle surfaces edgewise.
