odd behaviour with constraining a circle
kees_bijker
Member Posts: 171 ✭✭
Repeated here for answers! It is also in the section "ask a question"
In this document is an imported photo. I want to give it a reference for a new sketch to take measurements from the photo.
I drew a circle in the left crankshaft end. It does not show a dimension or position yet, so it is blue. I want to give it a dimension and it does not let me, what is wrong here? If I edit the sketch I should be able to dimensionalise this circle to fully define it.
In the real one I deleted the circle, did it again and assigned a diameter right from the time I drew the circle, and that works. Buit I am certain that you should also be able to define a dimension later in time, why is this not allowing me to assign a diameter?
The circle in question is orange. Please tell me because until I deleted it to start again this was driving me insane.
We have established that it is not only me having this issue. One commenter said he tried on his machine and it had the same behaviour.
Question is now is this a bug or are we going mad?
Sorry it took me so long to get a chance to help… See my response in the other thread…
