Cross Highlight with custom table
test_user291test_user291 Member Posts: 6
Hi,
I am using custom tables but i can't manage to get the cross hightlight between the row and the corresponding part. Do you know if there is a way to activate it ? Thank you for your answer.
  • chadstoltzfuschadstoltzfus Member, Developers, csevp Posts: 168 PRO
    Hard to know exactly what's not working without seeing the code. But all you should have to do is put the query to the entities you want to highlight in the tableRow function.
    So just
    tableRow({ "columnId" : columnValue }, queryToHighlight);
    chadstoltzfus@premiercb.com
    @chadstoltzfus nailed it.
    Don't forget to complete Onshape's FeatureScript Fundamentals Course.
    CADSharp does cover custom tables in detail in our CADSharp FeatureScript Course. But you should be set if you do what Chad mentioned.
    It depends on your specific application but I've found that sometimes it's nice to grab all edges and faces of the part and pass those into the query. That way if you select any edge of the part, it will highlight it in the table row.
    RENDERCAD
  • test_user291test_user291 Member Posts: 6
    Great ! Thank you very much. It works well now from CustomTable to 3D but not from 3D to CustomTable. Is it normal ? Is there a way to have the cross highlight in both ways ? Thank you for your answer.
    edited January 2025
    @test_user291 Are you sure your clicking the exact query that you put in the table? For example, if you put the entire part in the table, then you would need to click the entire part from the part tree in order to see it highlight the table. If you are putting edges and faces in the query too, then you will be able to click any edge or face of the part and it will highlight the corresponding row.
    RENDERCAD
